Старый 04.04.2018, 21:11   #1
emeadaxsupport: DIXF on SQL 2014 – Cannot Preview source file – CommunicationException – An error occurred while receiving the HTTP response from DMFServiceHelper.svc
Источник: https://blogs.msdn.microsoft.com/axs...icehelper-svc/
Consider a scenario where you are importing data using DIXF, and you get an error when you try to “Preview source file” and you are running SQL Server 2014 SP2 CU10 or CU11. 1. The error The error you see looks something like this: System.ServiceModel.CommunicationException: An error occurred while receiving the HTTP response to http://servernamehere:7000/DMFServic...viceHelper.svc. This... Read more
emeadaxsupport: DIXF - Importing Data - How to use Auto-generated to import PartyNumber Blog bot DAX Blogs 0 16.10.2015 21:11
emeadaxsupport: Moving AXModelstore from Source environment to Target environment with different DB collation Blog bot DAX Blogs 0 20.03.2015 16:11
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
NAV Team: Example of How to use SQL Tracing Feature to Profile AL Code Blog bot Dynamics CRM: Blogs 0 18.09.2012 20:43
Microsoft Dynamics CRM Team Blog: Accessing a SQL Database from a Microsoft Dynamics CRM Plug-in Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 15:15.
