Старый 10.01.2019, 17:12   #1
goshoom: Reference group and GROUP BY
Источник: http://dev.goshoom.net/en/2019/01/re...-and-group-by/
This blog post explains a problem that you can run into when using reference group controls with grouped data – and a solution for this problem.
I have a table which stores references to workers. The field has HcmWorkerRecId data type, i.e. it stores record IDs from HcmWorker table. When I drop this field to a grid on a form, the system uses Reference Group control, which shows human-readable data instead of RecId numbers. By default, it shows worker names.
There are multiple records for the same worker, therefore if I want to show data summarized data for each worker, I add grouping to the query:
TableWithRef_ds.queryBuildDataSource().addGroupByField(fieldNum(TableWithRef, Worker));
But the result isn’t correct – the reference group doesn’t show anything.
The grouping works correctly; I can see the right record IDs if I display them thought an Int64 control instead of a reference group.
The problem is that we group only by the record ID, but not by Name. And because Name is neither used in GROUP BY nor it has an aggregation function applied, its value is undefined and there is nothing to show.
Let’s fix it. Go to the data source in AOT and add reference data sources. Because Name field isn’t directly in HcmWorker table, we’ll need one more data source – DirPerson. Like this:
You can add them by right-clicking the Reference Data Sources node, choosing New Reference Data Source and then setting properties Join Relation and Name.
Then we can easily add an extra field to group by, this time from DirPerson table:
DirPerson_ds.queryBuildDataSource().addGroupByField(fieldNum(DirPerson, Name));
Voilà, names are back!
alirazazaidi: Custom lookup field and group reference field D365 for finance and operations Blog bot DAX Blogs 0 17.12.2018 15:12
Reference group & Edit метод. Не могу сообразить, как правильно сделать ( kitty DAX: Программирование 4 04.04.2018 16:58
Возможна ли reference group с display method Pandasama DAX: Программирование 0 24.11.2017 07:30
sunilrakesh: Reference group lookup in D365 (Ax7) Blog bot DAX Blogs 0 31.05.2017 17:11
Часовой пояс GMT +3, время: 03:45.
