Старый 24.01.2019, 01:15   #1
bugs in SysLookupMultiSelectGrid class and form
Источник: http://alexvoy.blogspot.com/2019/01/...rid-class.html
<div dir="ltr" style="text-align: left;" trbidi="on">You can find a lot of example about how to support multiple selection lookups. AX 2012/D365 provide us with SysLookupMultiSelectGrid class and form to implement such scenarios.
There are two bugs however still existing in the standard code.
SysLookupMultiSelectGrid class, method lookup() must be as follows in order to refresh Query in case QueryRun is given.
// the standard method does not update the query in case if queryrun is given
public static void wblLookup(Query _query, FormStringControl _ctrlIds, FormStringControl _ctrlStrs, container _selectField, queryRun _queryRun = null)
SysLookupMultiSelectGrid lookupMS = new SysLookupMultiSelectGrid();
lookupMS.parmCallingControlId(_ctrlIds);
lookupMS.parmCallingControlStr(_ctrlStrs);
lookupMS.parmQuery(_query);
lookupMS.parmQueryRun(_queryRun);
// Begin: Alexey Voytsekhovskiy
lookupMS.parmQuery(_queryRun.query());
// End: Alexey Voytsekhovskiy
lookupMS.parmSelectField(_selectField);
lookupMS.run();
SysLookupMultiSelectGrid form, method executeQuery() on common data source must be as follows in order not to consider referenced data sources, which may come with a given query.
<div style="background: #ffffff; border-width: 0.1em 0.1em 0.1em 0.8em; border: solid gray; overflow: auto; padding: 0.2em 0.6em; width: auto;">public void executeQuery()
QueryRun qr;
Query lookupMultiSelectQueryCopy = new Query(lookupMS.parmQuery());
FormRun formRun;
FormDataSource formDataSource;
int dsCount, i = 1;
Common formDataSourceCursor, queryRunCursor;
// Always use the query defined on the SysLookupMultiSelectGrid class. Note that a copy is used
// so that any modifications made to the Query by the Form at runtime aren't fed back through
// the next time the lookup is presented to the user. (The Query is used to define which fields
// are present on the Form during lookup construction. Therefore, if any fields are added at runtime
// by the Forms engine, duplicated or non-original-Query defined fields may be presented on the
// 2nd or later presentations of the lookup if a copy isn't used.)
this.query(lookupMultiSelectQueryCopy);
// check if user has set any queryrun. If yes, that means the cursors are set by user explicitly,
// usually the case where query contains tmp tables and needs to be populated.
qr = lookupMS.parmQueryRun();
if(qr)
formRun = this.formRun();
dsCount = formRun.dataSourceCount();
// get data source from query run, get the cursor and set it on the form data source cursor.
for(i = 1; i<span style="color: #333333;">
Старый 24.01.2019, 23:38   #2
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
админ, чо так криво грабится из блога?
Felix nihil admirari
Старый 25.01.2019, 02:39   #3
skuull is offline
skuull
700 / 752 (27) +++++++
Вы бы хоть проверили, что _queryRun не null, а то метод то публичный мало ли кто его вызовет только с query.
За это сообщение автора поблагодарили: wojzeh (1).
Старый 25.01.2019, 16:44   #4
wojzeh is offline
wojzeh
Аватар для wojzeh
ха-ха! зоркий глаз! видимо, отвалилось, когда копи-пастил; поправил. спасибо большое!
Старый 25.01.2019, 16:46   #5
wojzeh is offline
wojzeh
Аватар для wojzeh
следует использовать следующий код:
    if(_queryRun)
    lookupMS.run();
скуулу спасибо
За это сообщение автора поблагодарили: arhat (1).
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
dynamicsusers: How to find out which Form class and tables are used by a specific Dynamics AX form/functional process. Blog bot Dynamics CRM: Blogs 0 24.01.2008 19:53
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Часовой пояс GMT +3, время: 18:18.
