crmtipoftheday: Tip #1244: CDS connector may not fire in administration mode
Источник: https://crmtipoftheday.com/1244/cds-...stration-mode/
============== We did recommend using CDS Connector in Flow (more than once, actually) and most of the time it works great. However there have been some reports that CDS Connector does not trigger in the sandbox organizations while working fine in production. Turns out, there is a good explanation, straight from the source: With the new CDS Connector … the events are pushed to Flow/Logic Apps by the async server. The async processing … [is] turned off for custom logic due to the organizations being in “Admin Mode.”Here we go. If CDS Connector does not fire as expected in your Flows, check if your organization is in administration mode. Cover photo by unsplash-logoKristina Flour Источник: https://crmtipoftheday.com/1244/cds-...stration-mode/
