Старый 10.04.2019, 18:12   #1
crmtipoftheday: Tip #1250: Forms won’t load in Chrome
Источник: https://crmtipoftheday.com/1250/form...oad-in-chrome/
With Joel being busy or lazy, I’m claiming credit for that one even though I have nothing to do with it.
Problem: Classic UI [allegedly – t.j.] has an issue in v8.x where Chrome will just keep ‘spinning’ on some of the forms without returning anything.
Solution: Add an empty JS file to the form.
Explanation: Forms with no custom JS may not properly initialize the OOB script objects. Obviously a Microsoft/Chrome issue but, in a pinch, add an empty js file and that tells Dynamics to go initialize all javascript objects (including its own).
Joel trying to be funny: Legacy form rendering also works if you’re feeling destructive.
Time to upgrade: Unified interface doesn’t have this issue
crmtipoftheday: Tip #1209: Embedding canvas apps in model-driven forms Blog bot Dynamics CRM: Blogs 0 12.12.2018 14:11
crmtipoftheday: Tip #1164: All your forms are belong to us Blog bot Dynamics CRM: Blogs 0 31.08.2018 16:11
crmtipoftheday: Tip #1092: Chrome trick to make new field appear in the list Blog bot Dynamics CRM: Blogs 0 24.03.2018 00:15
crmtipoftheday: Tip #1070: Some Tips For Portal Web Forms Blog bot Dynamics CRM: Blogs 0 07.02.2018 14:12
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 17:58.
