Старый 17.05.2019, 17:11   #1
crmtipoftheday: Tip #1268: Restrict CDS instance creation
Источник: https://crmtipoftheday.com/1268/rest...ance-creation/
With P2 licensing, can you control who can spin up a CDS instance via Azure Active Directory since each license comes with 2 CDS instances? (we don’t want hundreds of CDS instances cluttering up our tenant)
The question from an enterprise business size UG member, generously relayed to us by Jerry “Forever Tipster” Weinstock
Via set-TenantSettings example towards end of the post
David F Yack
tl;dr
How to govern environment creation
Download and install the admin powershell cmdlets as described here. Read more about our cmdlets here.
$settings = @{ DisableEnvironmentCreationByNonAdminUsers = $true }Set-TenantSettings $settingsNote for PowerApps/Flow customers – If you use the new flag to restrict the environment creation, only tenant admin will have the ability to create new environments.
Personally, I like the suggestion that the default should be Opt-in not Opt-out. Or, as one of the commentators put it succinctly:
How quickly can I change that setting to false
crmtipoftheday: Tip #1175: CDS and data object prefix Blog bot Dynamics CRM: Blogs 0 09.10.2018 14:11
crmtipoftheday: Tip #1172: Make your CDS environments visible with a touch of Flow Blog bot Dynamics CRM: Blogs 0 12.09.2018 17:11
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
ошибка в AIF syl DAX: Программирование 14 20.08.2015 15:25
Часовой пояс GMT +3, время: 12:55.
