Старый 11.09.2019, 11:12   #1
crmtipoftheday: Tip #1305: Test and enable mailboxes failure because of throttling
Источник: https://crmtipoftheday.com/1305/test...of-throttling/
This next tip comes from Marius “Why are you still on-premises” Agur Lind. Got a tip of your own? Send it to jar@crmtipoftheday.com (and don’t forget to include either your Twitter handle or LinkedIn profile link for the eternal link appreciation).
Have you ever used an on-premise deployment and found that some testing and enabling mailboxes fail at weird intervals? Have you double, triple, and quadruple-checked the password and it’s still failing? Tried to see if dirsync is failing and updated the user password?
Well here’s what be ailing you:
Go check out the details of the warning message under alerts, andyou might just find the following:
System.Web.Services.Protocols.SoapException: The server cannot service this request right now. Try again later.
The reason why you’re getting this error is most probably because you’ve hit the outgoing email threshold of your Exchange Online. Wanna know how to fix it? Add more licenses.
Yes, I’m not kidding, the Exchange Online threshold policy isbased on the number of user licenses, so if you’re hitting this limit you justhave to try again later. There is no queue system, you just have to handle ityourself.
Exchange Online Throttling and Limits FAQ
Could be worse, but there you have it.
stoneridgesoftware: How To Enable Offline Mobile Access for Dynamics 365 Customer Engagement Blog bot Dynamics CRM: Blogs 0 31.07.2019 01:28
Microsoft Dynamics CRM Team Blog: Test and Enable Mailboxes in Microsoft Dynamics CRM 2015 Blog bot Dynamics CRM: Blogs 0 02.09.2015 00:11
crminthefield: CRM Online Test Instance Changes are now live (Sandbox Instances) Blog bot Dynamics CRM: Blogs 0 21.03.2014 21:14
Microsoft Dynamics CRM Team Blog: Using PowerShell to Enable SDK Message Throttling Blog bot Dynamics CRM: Blogs 0 02.06.2012 01:13
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
Часовой пояс GMT +3, время: 20:39.
