Старый 23.12.2019, 10:58   #1
Ventainais is offline
Ventainais
Hide, show dialog query select button.
Greetings!
I'm creating a new report and added to it a datasource.
The report is run from extended RunBaseReport Class and in the dialog method
I create a dialog in witch I added an enum type combobox.
What I am trying to do is hide the select button depending on what value the user has selected.
public Object dialog(Object _dialog)
    InventFertilizerReportDesign    inventFert;
    dlg     = super(_dialog);
    dlgFldDesignVal     = dlg.addField(typeId(InventFertilizerReportDesign), "@LVT76");
    dlgFldDesignVal.value(reportDesign);
    dlgFldDateFrom      = dlg.addField(typeId(TransDate), "@SYS5209");
    dlgFldDateFrom.value(dateFrom);
    dlgFldDateTo        = dlg.addField(typeId(TransDate), "@SYS80662");
    dlgFldDateTo.value(datoTo);
    dlgFldShopId        = dlg.addField(typeId(ReShopId));
    dlgFldShopId.value(shopId);
    dlgFldShowPrice     = dlg.addField(typeId(NoYes), "@LVT4117");
    dlgFldShowWeight    = dlg.addField(typeId(NoYes), "@LVT4119");
    return dlg;
In method "dialogPostRun" I set controlMethodOverload to true
super(dialog);
    dialog.dialogForm().formRun().controlMethodOverload(true);
    dialog.dialogForm().formRun().controlMethodOverloadObject(this);
public int Fld6_1_selectionChange()
    int     ret;
    Object          mainFormGroupOrig;
    Object  control = dlg.formRun().controlCallingMethod();
    ret = control.selectionChange();
    switch (dlgFldDesignVal.value())
        case InventFertilizerReportDesign::AmmoniaNitrateDesign :
            showQueryValues = true;
            dlgFldDateFrom.visible(true);
            dlgFldDateTo.visible(true);
            dlgFldShopId.visible(true);
            dlgFldShowPrice.visible(false);
            dlgFldShowWeight.visible(false);
            break;
        case InventFertilizerReportDesign::SalesReport          :
            showQueryValues = false;
            dlgFldDateFrom.visible(false);
            dlgFldDateTo.visible(false);
            dlgFldShopId.visible(false);
            dlgFldShowPrice.visible(true);
            dlgFldShowWeight.visible(true);
            break;
    reportDesign = dlgFldDesignVal.value();
    return ret;
 public boolean showQueryValues()
    return showQueryValues;
as simple it may be I can't figure out how to hide or show the button.
axapta 2012, hide, select button, show
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 5 Blog bot DAX Blogs 0 01.09.2014 14:11
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
daxline: How to show or hide query ranges on dialogs in Dynamics AX? Blog bot DAX Blogs 0 03.08.2011 09:11
Часовой пояс GMT +3, время: 06:49.
