Старый 16.12.2019, 07:30   #1
alirazazaidi: How to get calling menu name in extensions Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/ho...nd-operations/
Today is small tip,Many times, we have to took decision based on the name of menu on which form is called. By getting menu namewe can use same form for different purposes. We can write logic based on current form called from which menu item.
Following is thecode snippet helps you to achieve this.
[FormEventHandler(formStr(LogisticsContactInfoGrid), FormEventType::Initialized)]    public static void LogisticsContactInfoGrid_OnInitialized(xFormRun sender, FormEventArgs e)    {        FormRun formRun = sender;                if (formRun.args().menuItemName() == "CustomerLogisticsContactInfoGrid")        {            FormDataSource      LogisticsElectronicAddress_ds =formRun.dataSource("LogisticsElectronicAddress");            LogisticsElectronicAddress_ds.InsertIfEmpty(true);            LogisticsElectronicAddress_ds.object(fieldNum(LogisticsElectronicAddress, Locator)).mandatory(true);        }
alirazazaidi: Calling menu name in Extensions Dynamics 365 for finance and operations Blog bot DAX Blogs 0 23.03.2019 14:11
alirazazaidi: How to get table id in Dynamics 365 for finance and operations. Blog bot DAX Blogs 0 15.01.2019 18:13
alirazazaidi: List of best blog post and article for Customization with extensions. Dynamics 365 for finance and operations Blog bot DAX Blogs 0 05.01.2019 12:19
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 18:54.
