Старый 12.02.2020, 16:11   #1
crmtipoftheday: Tip #1323: Kill the case customer field
Источник: https://crmtipoftheday.com/1323/kill...ustomer-field/
The “Customer” field on cases is a bad idea, and you can’t change it to not-required. I just want to add a lookup to accounts and automatically populate the customer field.
Anonymous reader “Meve Stordue”
You can’t make the customer field non-required, but it is possible to replace it with an account lookup and automatically populate the customer field with the account selected in the custom lookup field.
Read the tip
crmtipoftheday: Tip #1293: Make case customer a contact Blog bot Dynamics CRM: Blogs 0 12.08.2019 16:11
crmtipoftheday: Tip #1292: Use the Route Case field Blog bot Dynamics CRM: Blogs 0 10.08.2019 04:57
Get Model element type name from its ID Blog bot DAX Blogs 0 14.02.2017 01:13
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 06:17.
