Старый 08.07.2020, 22:14   #1
Event handler: Get access from FormDataSource argument to other data sources and form controls
Источник: http://alexvoy.blogspot.com/2020/07/...cess-from.html
Kind a code template to accelerate our job:
[FormDataSourceEventHandler(formDataSourceStr(, ), FormDataSourceEventType::Activated)]
public static void FormDataSourceName_OnActivated(FormDataSource _sender, FormDataSourceEventArgs _e)
formDataSourceTable = _sender.cursor();
FormRun formRun = _sender.formRun();
FormDataSource anyFormDataSource_ds = formRun.dataSource(formDataSourceStr(, )) as FormDataSource;
anyFormDataSourceTable = anyFormDataSource_ds.cursor();
FormControl anyFormControl = formRun.design(0).controlName('AnyFormControlName');
// your logic goes here, for example if(formDataSourceTable.enabled())
anyFormControl.visible(false);
anyFormControl.enabled(!anyFormDataSourceTable.RecId);
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
Часовой пояс GMT +3, время: 11:04.
