Старый 07.10.2020, 03:12   #1
25,644 / 848 (80) +++++++
powerobjects: D365 Finance and Operations Navigational Tips
Источник: https://powerobjects.com/2020/10/06/...gational-tips/
If you are new to Dynamics 365 or have upgraded to D365 from an earlier version of AX, you probably need help navigating the waters! There are beacons of light you may not be aware of that can help keep you between the navigational buoys! Let’s explore 3 very easy options… First, the navigation bar can be enabled (by your system administrator), which displays the navigation breadcrumb trail...
Source
powerobjects: Using Azure KeyVault to Encrypt D365 for Finance & Operations Data Blog bot Dynamics CRM: Blogs 0 09.10.2018 02:23
D365 for FO Tips&Tricks: Calling PowerApps from D365 for Finance and Operations Blog bot DAX Blogs 0 14.08.2018 17:11
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
powerobjects: Electronic Reporting in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 14.02.2018 03:28
Часовой пояс GMT +3, время: 21:49.
