Старый 28.09.2021, 19:12   #1
d365technext: Mandatory Field with user Personalization
Источник: https://d365technext.blogspot.com/20...with-user.html
This feature is available in Version 10.0.12, and you can enable this feature from feature management.
Many times we receive requests from the customers that for their internal control purpose they want to make few fields mandatory in the particular form.
Earlier we had to connect with the technical team and make it mandatory but now it's not required. End-user itself can make the field mandatory base on requirements.
Here are the steps you can follow to achieve this requirement.
Ste-1
Go to the feature management and enable the feature like below.
Step-2
Go to the form, on which you want to make the field Mandatory.
Step-3 Right Click > Personalize Field > Select required Check box option
Step-4
You will get the message like below when will you try to save the record without entering the value in the field.
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
stoneridgesoftware: User Personalization in Dynamics NAV: Work Smart, Not Hard Blog bot NAV: Blogs 0 13.04.2018 21:14
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
Часовой пояс GMT +3, время: 10:01.
