Старый 23.12.2021, 05:30   #1
25,644 / 848 (80) +++++++
domhk: Taking JSON input with D365 service and deserialize into contract class
Источник: https://domhk.blogspot.com/2021/12/t...rvice-and.html
Recently I wanted to create a custom serivce in D365 taking in a JSON input. I did my usual google search but ended up needing additional trial and error to complete the use case. Here I'll share the solution I have..
Firstly, create a contract class which represent the a Json object
/// The Student Information object contains the Student ID and Name
[DataContractAttribute]
class StudentInfoContract
str studentId;
str studentName;
[DataMemberAttribute("Student Id")]
public str parmStudentId(str _studentId = studentId)
studentId = _studentId;
return studentId;
[DataMemberAttribute("Student Name")]
public str parmStudentName(str _studentName = studentName)
studentName = _studentName;
return studentName;
Then, in the service contract class, define a List of Str which will take in the Json
/// Contains a list of students
class StudentsContract
List studentList = new List(Types::String);
DataMemberAttribute("Student list"),
DataCollectionAttribute(Types::Class, classStr(StudentInfoContract))
public List parmStudentList(List _studentList = studentList)
if (!prmIsDefault(_studentList))
studentList = _studentList;
return studentList;
At run time, when calling code provides a list of Json objects, it'll be come a list of JObjects in X++. We'll loop through the list and use FormDeserializer to deserialize each JObject into a contract instance
List studentList = StudentsContract.parmStudentList();
ListEnumerator enumerator = studentList.getEnumerator();
while (enumerator.moveNext())
Newtonsoft.Json.Linq.JObject jObj = enumerator.current();
studentInfoContract = FormJsonSerializer::deserializeObject(classNum(StudentInfoContract),jObj.ToString());
str studentId, studentName;
studentId = studentInfoContract.parmStudentId();
studentName = studentInfoContract.parmStudentName();
Info(strFmt("Studnet # %1: %2", studentId, studentName));
In the end it's quite simple, and also no need to create C# class representing the data contract as well.
d365fo, json, интеграция
Navigate Into Success: Passing JSON from JavaScript to C/AL Blog bot Dynamics CRM: Blogs 0 31.12.2014 10:00
Navigate Into Success: Long time no see, Vienna, Nashville, demo gods, and other things Blog bot Dynamics CRM: Blogs 0 09.10.2013 01:15
Navigate Into Success: Web Reference vs. Service Reference, Part 3 Blog bot Dynamics CRM: Blogs 0 31.01.2012 04:44
Navigate Into Success: Web Reference vs. Service Reference, Part 2 Blog bot Dynamics CRM: Blogs 0 30.01.2012 11:04
Creating Custom Dynamics AX Services Blog bot DAX Blogs 0 17.12.2008 12:05
Часовой пояс GMT +3, время: 16:29.
