Старый 12.02.2022, 00:13   #1
Additional parameters in RunBaseBatch class extension
Источник: http://alexvoy.blogspot.com/2022/02/...basebatch.html
Old good pack/unpack patterns with SysPackExtension call. Say, we need to augment RunBaseBatch based class .
/// We are going to use a new additional parameter///
[ExtensionOf(classStr())]
public final class My_Extension{
private boolean myNewParm; #define.CurrentVersion(1)
#localmacro.CurrentList
myNewParm
#endmacro
/// myNewParm access
/// boolean
/// boolean
public boolean parmMyNewParm(boolean _parm = myNewParm)
myNewParm= _parm;
return myNewParm;
/// Extends Pack
/// container
public container pack()
container packedClass = next pack();
return SysPackExtensions::appendExtension(packedClass, classStr(My_Extension), this.myPack());
/// Extends Unpack
/// container
/// boolean
private boolean myUnpack(container packedClass)
Integer version = RunBase::getVersion(packedClass);
switch (version)
case #CurrentVersion:
[version, #currentList] = packedClass;
break;
default:
return false;
return true;
/// Packs my locals
/// container
private container myPack()
return [#CurrentVersion, #CurrentList];
/// Extends unpack
/// container
/// boolean
public boolean unpack(container _packedClass)
boolean result = next unpack(_packedClass);
if (result)
container myState = SysPackExtensions::findExtension(_packedClass, classStr(My_Extension));
//Also unpack the extension
if (!this.myUnpack(myState))
result = false;
return result;
d365technext: Class Extension D365FO Blog bot DAX Blogs 0 08.08.2018 14:11
goshoom: Class extensions Blog bot DAX Blogs 0 18.07.2016 17:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
Часовой пояс GMT +3, время: 00:30.
