D365FO: SysMultiTableLookup - dynamic lookups based on multiple tables
Источник: http://alexvoy.blogspot.com/2022/06/...p-dynamic.html
============== Yes, guys, sometimes they come back! Fourteen years ago Vania Kashperuk created a class which became classics: SysMultiTableLookup. It made possible to create lookups based on multiple tables. Some people are still looking for it in vain among the standard classes. So I decided to create a new version of it for D365FO. It combines supporting for both lookup and lookupReference methods: performFormLookup and performFormReferenceLookup. Vania added a tutorial form to his class, so did I. There is a form in the project, which shows how unbounded form controls can be looked up with fields and display methods from joined tables as well as the case with aggregation and a CustTable data source to demonstrate a lookup for a reference group. Take note that I did not implement resolving and have not tested it thoroughly, neither. Feel free to use it and elaborate at your own risk. The whole project tmxSysMultiTableLookup is here in https://github.com/wojzeh/tmxSystemTools The only class is here <div style="background: rgb(255, 255, 255); border-color: gray; border-image: initial; border-style: solid; border-width: 0.1em 0.1em 0.1em 0.8em; border: solid gray; overflow: auto; padding: 0.2em 0.6em; width: auto;">/// /// Multi table lookup. D365FO version based on the original by Vanya Kashperuk /// http://kashperuk.blogspot.com/2008/0...c-lookups.html /// public class tmxSysMultiTableLookup extends SysTableLookup { FormBuildInt64Control recIdSelectModeControl; boolean isReference; /// /// Is reference lookup /// /// boolean /// True if Reference protected boolean parmIsReference(boolean _parm = isReference) { isReference = _parm; return isReference; } /// /// Places the specified form into the correct lookup selection mode. /// /// /// The form to be put into lookup selection mode. /// protected void setSelectMode(FormRun _formRun) { if(isReference) { if (!recIdSelectModeControl) { throw(error(Error::wrongUseOfFunction(funcname()))); } _formRun.selectRecordMode(_formRun.control(recIdSelectModeControl.id())); } else { super(_formRun); } } /// /// Constructs tmxSysMultiTableLookup for a formcontrol with a given query /// /// Target form Reference group control /// Query /// Use input value /// AmbiguousReferenceResolver /// Instance of tmxSysMultiTableLookup static tmxSysMultiTableLookup newReferenceParameters(FormReferenceControl _callingControl, Query _query, boolean _useLookupValue = true) { tmxSysMultiTableLookup sysTableLookup = tmxSysMultiTableLookup::construct(); if(_query.dataSourceCount() < 1) { throw error(@"Query needs to be defined before building the lookup"); } sysTableLookup.parmIsReference(true); sysTableLookup.parmQuery(_query); sysTableLookup.parmCallingControl(_callingControl); sysTableLookup.parmUseLookupValue(_useLookupValue); return sysTableLookup; } /// /// Constructs tmxSysMultiTableLookup for a formcontrol with a given query /// /// Target form control /// Query /// Use input value /// AmbiguousReferenceResolver /// Instance of tmxSysMultiTableLookup static tmxSysMultiTableLookup newParameters(FormControl _callingControl, Query _query, boolean _useLookupValue = true) { tmxSysMultiTableLookup sysTableLookup = tmxSysMultiTableLookup::construct(); if(_query.dataSourceCount() < 1) { throw error(@"Query needs to be defined before building the lookup"); } sysTableLookup.parmQuery(_query); sysTableLookup.parmCallingControl(_callingControl); sysTableLookup.parmUseLookupValue(_useLookupValue); return sysTableLookup; } /// /// Instantiates tmxSysMultiTableLookup /// /// tmxSysMultiTableLookup static tmxSysMultiTableLookup construct() { return new tmxSysMultiTableLookup(); } /// /// Adds form control /// /// Datasource number in the query /// Field num /// Return item /// Method name /// Label void addLookupControlMulti(int _dataSourceNo, fieldId _fieldId, boolean _returnItem, str _methodName, str _label) { lookupItems += [[_dataSourceNo, _fieldId, _returnItem, _methodName]]; if (_label) { this.setLabel(_label); } } /// /// Adds field as form control /// /// Method name /// Datasource number in the query /// Label void addLookupMethodMulti(str _methodName, int _dataSourceNo = 1, str _label ="") { this.addLookupControlMulti(_dataSourceNo, 0, false, _methodName, _label); } /// /// Adds field as form control /// /// Datasource number in the query /// Field num /// Return item /// Label void addLookupFieldMulti(fieldId _fieldId, int _dataSourceNo = 1, boolean _returnItem = false, str _label = '') { if (_dataSourceNo > query.dataSourceCount()) { throw error(Error::wrongUseOfFunction(funcName())); } this.addLookupControlMulti(_dataSourceNo, _fieldId, _returnItem, '', _label); } /// /// Chooses LinkType appropriate to JoinMode /// /// JoinMode /// FormLinkType protected FormLinkType joinMode2LinkType(JoinMode _joinMode) { switch (_joinMode) { case JoinMode::InnerJoin: return FormLinkType::InnerJoin; case JoinMode::OuterJoin: return FormLinkType::OuterJoin; case JoinMode::ExistsJoin: return FormLinkType::ExistJoin; case JoinMode::NoExistsJoin: return FormLinkType::NotExistJoin; } throw error(Error::wrongUseOfFunction(funcName())); } /// /// Configures the data source of the lookup form. /// /// FormBuildDataSource /// QueryBuildDataSource protected void configureLookupDataSourceMulti(FormBuildDataSource _formBuildDataSource, QueryBuildDataSource _queryBuildDataSource) { this.configureLookupDataSource(_formBuildDataSource); if(_queryBuildDataSource.embedded()) //joined() or level() > 1 { _formBuildDataSource.linkType(this.joinMode2LinkType(_queryBuildDataSource.joinMode())); _formBuildDataSource.joinSource(_queryBuildDataSource.parentDataSource().name()); } } /// /// Builds grid form control /// /// FormBuildGridControl /// Form /// FormBuildGridControl protected FormBuildGridControl buildGridMulti(FormBuildGridControl _formBuildGridControl, Form _form) { FormBuildDataSource formBuildDataSource; FormBuildControl formBuildControl; Object obj; boolean returnItem; str method; int fieldId; int i; boolean lookupFieldSet = false; int dataSourceNo; fieldId recIdFieldId; boolean firstDS = true; // add fields and display methods for all given data sources for (i = 1; i 1) { throw error("Multiple temporary datasource lookups are not supported"); } formDataSource.init(); //BP deviation documented formDataSource.cursor().setTmp(); formDataSource.cursor().setTmpData(tmpBuffer); } this.setSelectMode(formRun); this.buildSelectionListMulti(formDataSource.query()); this.addFilter(formRun); return formRun; } /// /// Creates selection list from a given query /// /// Query protected void buildSelectionListMulti(Query _query) { boolean returnItem; str method; int fieldId; int i; int dataSourceNo; SelectionField fieldKind() { int j; QueryBuildFieldList qbfl; qbfl = _query.dataSourceNo(dataSourceNo).fields(); for (j = 1; j
