Старый 15.12.2022, 13:11   #1
ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Miha Vuk
Источник: https://ax.docentric.com/configure-s...#comment-10869
In reply to Omar Frassinotti. Hi Omar, This article describes how to establish the trust between Azure application called Microsoft Dynamics ERP (created by Microsoft) with ID 00000015-0000-0000-c000-000000000000 and your SharePoint. Up to April 2022 all local OneBoxes were using this ID and it still works if you follow our steps. However you can create your Azure application and use its ID, but then you have to adjust the scripts. If you have an already provisioned environment I would recommend the following:
  1. Revert you C:\DynamicsTools\CleanVHD folder back to original state. If you do not have it, you can get it here.
  2. Run steps from section "On new April 2022 OneBox" without S2S certificate. Find the thumbprint of generated S2S certificate in web.config Infrastructure.S2SCertThumbprint.
  3. Run steps from section "Enable authentication with the S2S certificate from OneBox in AAD" with you new S2S certificate (select it in step 2).
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
Часовой пояс GMT +3, время: 14:59.
