Старый 21.08.2023, 19:14   #1
25,644 / 848 (80) +++++++
Alexdmeyer: Import Number Sequences via Data Entity
Источник: https://alexdmeyer.com/2023/08/21/im...a-data-entity/
Overview Number sequences are used to generate readable, unique identifiers for master data records and transaction records. These sequences are normally one of the first things set up after a legal entity is deployed. When either implementing or migrating these number sequences between environments you can utilize either the ‘SequenceTables’ or ‘SequenceV2Tables’ data entities to […]
The post Import Number Sequences via Data Entity appeared first on Alex Meyer.
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
stoneridgesoftware: Automated Data Entity Import Using DIXF in Dynamics AX Blog bot DAX Blogs 0 07.08.2017 20:19
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 19:01.
