Navision 2.5 SQL option. Error during database creation
Hi, please could anyone help me to solve a problem. I have Navision 2.5. I ‘d like to move to SQL Server option. I have proper license to do this.
My OS is Windows 2000 and I have SQL 2000 Enterprise edition. I have only American English and nothing else installed. I use menu File->Database-> New->General tab to crate a new database In navision. I have following error after I input database name on General tab. --------------------------------------------------------- The Current ANSI or OEM code page on you computer does not match the 0 code page on the SQL server. You must ensure that either the ANSI or OEM code page matches the server code page. --------------------------------------------------------- My default server collation is SQL_Latin1_General_CP_CI_AS. Thank you very much for your help, Vic |
Возникла похожая проблема, только при открытии базы.
Версия 2,60 на SQL. Клиента запускаю на сервере, там по определению кодовая страница одна и та же. Server collation: Cyrillic_General_CI_AS Какие версии есть? |
try to use MS SQL 7.0.
imho, navision 2.5 doesn t work with sql 2000. system tables of sql 2000 is different from MS SQL 7.0. - this is the source of error. |
Опции просмотра | |
