Старый 14.05.2008, 01:12   #1
25,643 / 848 (80) +++++++
How to delete modifications on few layers
Источник: http://alexvoy.blogspot.com/2008/05/...ew-layers.html
As it is well known:
Modifications are saved in an application layer which is also specified in the configuration. All modifications to application objects in a layer are saved in a file named ax.aod.
If you need to brush off you configuration the simplest way is to do that is just to delete all those files on the file server. The only issue may be if the system is running and, therefore, those are locked.
If that case you have the other way. For example you need to dispose everything that was made on VAR and USR layers.
Open the AOT and create a new project, e.g. LayersVarUsr
Open it and use Advanced Filter/Sort tool on the toolbar or Ctrl-F3
Check AOT and open Inquiry form by clicking Select button
Here you should set the rule for utilLevel field, in our case VAR..USP to include all modifications made on these layers with patch ones as well.
Be patient, it can take much time. When the DAX finishes you will get everything to accomplish your seek-and-destroy mission.
By the way, you can take advantage of using Compare tool to decide what will next happen.
mfp: New Layers in Dynamics AX 2009 Blog bot DAX Blogs 0 24.04.2008 20:19
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
jerry-dynamics: How can you make sure that the end user can not delete a record in one table if there are related records in another table? Blog bot DAX Blogs 0 16.06.2007 11:20
How do I delete a datasource from a query ? (by stelsig) Maxim Gorbunov DAX in English 0 22.03.2006 12:21
Часовой пояс GMT +3, время: 04:57.
