Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 19.01.2007, 12:44   #1
ginmur is offline
ginmur
? Unable to edit/delete classes in AOT - AX3 SP3
I have a strange problem with AOT. Suddenly (maybe after my programming lessons) it is somehow "locked". I'm not able to edit classes in AOT. I can however edit reports.
But when I edit a class, save the changes, then during debug I see the old code. When opening the metod for editing, the new code is there. But when restarting AX, the changes disapear.
Also I;m not possible to delete any of the method.
The changes are in usr layer, I;m logged into usr layer.
I already compiled AOT, deleted aoi file, nothing helped.
Any ideas?
Старый 19.01.2007, 12:57   #2
EVGL is offline
EVGL
4,445 / 3001 (0) ++++++++++
You have no license for "X++ source code".
За это сообщение автора поблагодарили: ginmur (1).
Старый 19.01.2007, 13:04   #3
ginmur is offline
ginmur
Thumbs up
thank you very much, that's exactly the problem. So now I know I have to do changes under another license :-(
Старый 19.01.2007, 13:12   #4
ginmur is offline
ginmur
but how it is possible to delete the class from AOT without this license, especially when I imported in accidentally, and it is only on this layer?
После установки KR2 на AX3 SP3 не пускает на AOS больше 100 пользователей Alexandr A. Osipkin DAX: Администрирование 14 06.12.2008 02:33
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
Куда пропадают лицензии в Ax3.0 SP3 KR2? falcon65 DAX: Администрирование 2 10.05.2007 09:55
Ax3.0 SP3 CIS: Журнал накладных и российские договора (ошибка) mpa DAX: Функционал 2 11.10.2004 15:14
Часовой пояс GMT +3, время: 23:31.
