Старый 14.08.2007, 17:04   #1
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Надежный способ убить AOS (4.0)
// AOSMode:Server
class CrashTheAOS
static void main(Args _args)
    Map         testMap = new Map(Types::Integer, Types::Class);
    container   packedMap;
    testMap.insert(1, new SmmUpdateFinancial());
    packedMap = testMap.pack();
    testMap = Map::create(packedMap); // Bang!!!
                                      // the class SmmUpdateFinancial doesn't have ::create(...)
ax4.0
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: Multiple AOS in a Multi CPU Machine :) Blog bot DAX Blogs 1 19.12.2007 17:11
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
DynamicsTech: What's New in Dynamics Ax 4.0 AOS? Blog bot DAX Blogs 0 12.04.2007 11:50
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
Часовой пояс GMT +3, время: 04:42.
