Старый 26.01.2008, 18:22   #1
Khue Trinh: Set up & perform Global Search
Источник: http://khue.spaces.live.com/Blog/cns...A0C2!403.entry
Set up and start the Data Crawler
Go to Basic>Set up>Data Crawler>Table Setup
Create a new record, select Address table. Click OK to add all text fields into Text Index.
Click on Text Index tab page to check, check the checkbox "Enable Text Index".
Go to Basic > Setup > Data Crawler > Data Crawler .
On the Overview tab, select a company.
On the Crawler tab, if the status is Stopped , select a crawler speed and then click Start crawler .
Performing a global search
Press CTRL+F to open the Global Search pane.
In the Search for field, type the text you are searching for, and then press ENTER.
To filter the results of your search, select a category from the Categories list.
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
Khue Trinh: Adjust Standard Cost of Item Blog bot DAX Blogs 1 30.04.2008 15:08
Khue Trinh: Inventory Min/Max Key Blog bot DAX Blogs 0 13.01.2008 19:32
Khue Trinh: Mass Deployment of the Microsoft Dynamics AX Client Blog bot DAX Blogs 0 07.01.2008 15:51
Khue Trinh: RESERVATION AT A GLANCE Blog bot DAX Blogs 0 07.01.2008 15:51
Часовой пояс GMT +3, время: 15:11.
