Старый 15.08.2008, 04:15   #1
memory leak in Axapta 3.0
Источник: http://alexvoy.blogspot.com/2008/08/...axapta-30.html
Recently having got an error message after using AOS for batch processing I started digging this problem and finally found out that was described in Fixlist of Service Pack 5.
(Problem #1748 Processing some X++ code constructions resulted in a memory leak.)
You may see the same error by creating a job like the following one as it was suggested in Fixlist in order to reproduce the message. I just increased the number of iteration and an info to see the progress.
static void MemoryLeakTest(Args _args)
container custcont;
int loop;
Custtable custtable;
select custtable;
custcont = conins(custcont,1,custtable.data());
for(loop = 1; loop
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 22.11.2006 15:20
Axapta Lessons: Integrating Microsoft Axapta with Microsoft Office and Microsoft SharePoint Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 15:06.
