Старый 27.08.2008, 18:05   #1
Ruslan Goncharov: Storing report design in database
Источник: http://rusgon.blogspot.com/2008/08/s...-database.html
Today I'd like to say a few words about packDesign()/unpackDesign() methods.
As a matter of fact we may store report design just in database. All we need is new container field in table where report design is storing.
Following job demonstrates storing technique.
When restore is false - we store the design. Else we restore design.static void JobReportDesign(Args _args)
{ Report report = new Report(); ReportRun reportRun; ReportDesign reportDesign; ReportSection reportSection; ReportTextControl reportTextControl; Table1 Table1;// boolean restore = true; boolean restore = false; BinData binData; void runReport(ReportRun _reportRun) { ReportDesign _reportDesign = _reportRun.report().design(); int sCount = _reportDesign.sectionCount(); int i; ; for(i=1; i if(restore) { select Table1 where Table1.ItemId == '000000000001'; reportRun.unpackDesign(Table1.FieldReportDesign); runReport(reportRun); report.interactive(false); reportRun.run(); return; } // ReStore the report if(!restore) { ttsbegin; select forupdate Table1 where Table1.ItemId == '000000000001'; Table1.FieldReportDesign = reportRun.packDesign(); Table1.update(); ttscommit; } <span class="co1">// Store the report
Ruslan Goncharov: A few words about sorting codes Blog bot DAX Blogs 0 18.02.2009 21:05
Ruslan Goncharov: From Microsoft Dynamics AX Programming newsgroup tricks Blog bot DAX Blogs 0 24.05.2008 00:08
Ruslan Goncharov: Quick sorting in info messages Blog bot DAX Blogs 0 09.02.2008 19:11
Ruslan Goncharov: How to clarify what happened with variables in AX Blog bot DAX Blogs 0 17.01.2008 15:40
Palle Agermark: Runtime modification of Auto Design report sections Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 01:08.
