emeadaxsupport: Forms opening up with focus in background?
Источник: http://blogs.msdn.com/b/axsupport/ar...ackground.aspx
============== If you work with an installation where forms in MS Dynamics AX are opened in the background then the following code fix might help out here: “Microsoft provides programming examples for illustration only, without warranty either expressed or implied, including, but not limited to, the implied warranties of merchantability or fitness for a particular purpose. This mail message assumes that you are familiar with the programming language that is being demonstrated and the tools that are used to create and debug procedures.” Add a new static, client-side method to Classes\Application, as below: client static void disableWindowGhosting() { DLL DLL; DLLFunction DLLFunction; container con = WinAPI::getVersion(); ; if (conpeek(con, 1) == 6) //Vista and Win7/Win2008R2 only { //this will disable window ghosting for this process only, for its lifespan only DLL = new DLL('USER32'); DLLFunction = new DLLFunction(DLL,'DisableProcessWindowsGhosting'); DLLFunction.call(); } } Add a call to this from Application.startupPost(), like this: … if (hasGUI()) { Application::DisableWindowGhosting(); } … Источник: http://blogs.msdn.com/b/axsupport/ar...ackground.aspx
