Старый 05.11.2008, 00:58   #1
A number of people have asked for guidance on how to transfer data to/from COM and WebServices in NAV 2009.
I the following I will go through how to get and set a picture on an item in NAV through a Web Service Connection. I will also show how you can create an action in NAV, which allows you to transfer a picture from an item to Paint (on the Client) modify it and Save it back into NAV.
During these scenarios we will run into a number of obstacles - and I will describe how to get around these.
First of all - we want to create a Codeunit, which needs to be exposed to WebServices. Our Codeunit will contain 2 functions: GetItemPicture and SetItemPicture - but what is the datatype of the Picture and how do we return that value from a WebService function?
The only datatype (supported by Web Services) that can hold a picture is the BigText datatype.
We need to create the following two functions:
GetItemPicture(No : Code[10];VAR Picture : BigText)
SetItemPicture(No : Code[10]; Picture : BigText);
BigText is capable if holding binary data (including null terminals) up to any size. On the WSDL side these functions will have the following signature:
xxxxx
As you can see BigText becomes string - and strings in .net are capable of any size and any content.
Подробнее
Часовой пояс GMT +3, время: 09:51.
