Старый 07.11.2008, 09:05   #1
Solutions Monkey: Programatically reading data from AxDataSourceControl
Источник: http://blogs.msdn.com/solutions/arch...cecontrol.aspx
DataSourceControl makes it simple to get Ax data and display it in DataBound UI controls and manipulate the data. You can also use them to read data programtically. Below is one way of doing it. The other way to get Ax data programatically is to get the DataSet directly using MetaDataCahce object and reading data.
private void GetData()
DataSourceViewSelectCallback callback = new DataSourceViewSelectCallback(PrintData);
AxDataSource1.GetDataSourceView("CustTable").Select(DataSourceSelectArguments.Empty,callback);
private void PrintData(IEnumerable data)
IEnumerator i = data.GetEnumerator();
while (i.MoveNext())
Response.Write(DataBinder.Eval(i.Current, "AccountNum").ToString() + “”);
Старый 07.11.2008, 09:17   #2
смотрю на последние блоги и тихонько офигеваю.
что ж они такое делают, что ТАКОЕ они считают полезным и нужным к публикации?
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Solutions Monkey: Opening Enterprise Portal page in a new window from the Quick Launch Blog bot DAX Blogs 0 06.10.2007 06:51
Solutions Monkey: Enterprise Portal Demo script – 2 Blog bot DAX Blogs 0 18.02.2007 15:11
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Solutions Monkey: EP Samples from TechReady3 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 19:29.
