Старый 23.09.2009, 19:05   #1
wookiecrm: Javascript : How to find out which action raised the OnSave event in a Form
Источник: http://feedproxy.google.com/~r/Wooki...in-a-form.html
Recently, I was asked by a customer if it was possible to execute some javascript when an Opportunity is marked as won. As you all know, the value of statecode is in fact on a separate dialog box and technically, there is no way to capture the event. However, this is another way around it, and that is the use the event.Mode value to determine which action raised the OnSave event in the first place.
Here is the list of events:
  • None : 0
  • Save : 1
  • SaveAndClose : 2
  • Delete : 3
  • Load : 4
  • Deactivate : 5
  • Reactivate : 6
  • Email Send : 7
  • Email Reply : 8
  • Email Forward : 9
  • Kb Submit : 10
  • Kb Reject : 11
  • Kb Publish : 12
  • Kb UnPublish : 13
  • Kb Rate : 14
  • Lead Unqualify : 15
  • Lead Qualify : 16
  • Quote Accept : 17
  • Quote CreateOrder : 18
  • Order ProcessOrder : 19
  • Opportunity AddRelatedOrder : 21
  • Opportunity AddRelatedQuote : 22
  • Opportunity AddRelatedInvoice : 23
  • Quote CreateRevision : 24
  • Quote CloseQuote : 25
  • Order CancelOrder : 26
  • Invoice Close : 27
  • Quote GetProducts : 28
  • Quote Activate : 29
  • Email ReplyAll : 30
  • Contract Hold : 31
  • Contract ReleaseHold : 32
  • Contract Cancel : 33
  • Contract Renew : 34
  • Product ConvertToKit : 35
  • Product ConvertFromKit : 36
  • ContractDetail Cancel : 37
  • Contract Invoice : 38
  • Contract Clone : 39
  • Incident Cancel : 40
  • Email Assign : 41
  • Change SalesStage : 42
  • SalesOrder GetProducts : 43
  • InvoiceGetProducts : 44
  • TemplateMakeOrgAvailable : 45
  • TemplateMakeOrgUnavailable : 46
  • Assign : 47
  • IncidentAssignToUser : 49
  • OrderLock : 50
  • OrderUnlock : 51
  • InvoiceLock : 52
  • InvoiceUnlock : 53
  • ConvertResponse : 54
  • ReportMakeOrgAvailable : 60
  • ReportMakeOrgUnavailable : 61
  • WorkflowAddCheckStep : 62
  • WorkflowUpdateCondition : 63
  • WorkflowCreateAction : 64
  • SendInvite : 65
  • WorkflowAddElseIfStep : 66
  • WorkflowAddElseStep : 67
  • WorkflowDeleteStep : 68
Example Usage :
if(event.Mode == 5) //deactivation
// Do some custom logic here
If you dont know which action triggered the event, you can use the following line in the onSave event of the form to find out :
alert(event.Mode);
a33ik: How to call/launch/execute workflow and wait until its execution to make some action with JavaScript in Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 1 09.09.2009 17:27
emeadaxsupport: How to open an AX form from your own help Blog bot DAX Blogs 0 26.07.2009 15:07
How To Resrtict Form Setup Conext Menu Item Blog bot DAX Blogs 0 01.05.2009 04:13
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Часовой пояс GMT +3, время: 19:35.
