Старый 12.10.2009, 20:05   #1
CRM Programmer: Registering plugins for event on many-to-many entities
Источник: http://crmpro.blogspot.com/2009/10/r...t-on-many.html
I found that from the box MS CRM 4.0 are not supported the events on many-to-many relationship entities(bridge entities). But Aaron Elder has hack it.
All you need is just register it at AssociateEntities or DiassociateEntities event with empty Primary and Secondary Entity fields.
-- Enable Associate and Disassociate Plug-in Events Script v1.0
-- (c) 2009 Aaron Elder
-- DISCLAIMER:
-- This script is provided "AS IS" with no warranties, and confers no rights.
-- While this is obviously "unsupported", I think the fact that these events
-- are not available is a bug and hopefully it will be fixed in a rollup.
USE AscentiumCrmDev_MSCRM
GO
-- Find the deployments SDK Filter ID for the
-- Associate and Disassociate Entity SDK Messages
DECLARE @DisassociateEntitiesFilterId uniqueidentifier
DECLARE @AssociateEntitiesFilterId uniqueidentifier
SET @DisassociateEntitiesFilterId = (SELECT SdkMessageId FROM SdkMessageBase WHERE [Name] = 'DisassociateEntities')
SET @AssociateEntitiesFilterId = (SELECT SdkMessageId FROM SdkMessageBase WHERE [Name] = 'AssociateEntities')
-- Enable the Associate and Disassociate Filters to be valid for custom processing
-- Custom Processing means "you register plug-ins against it"
-- Note: We only do this for the "generic" (OTC == 0) case, just to be safer
UPDATE SdkMessageFilterBase SET IsCustomProcessingStepAllowed = 1
WHERE SdkMessageId = @DisassociateEntitiesFilterId AND PrimaryObjectTypeCode = 0
WHERE SdkMessageId = @AssociateEntitiesFilterId AND PrimaryObjectTypeCode = 0
(C)
http://consulting.ascentium.com/blog/crm/Post533.aspx
CRM Programmer: Remove 'Add Existing...' button from associated view entities form Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Microsoft Dynamics CRM Team Blog: Data Design for CRM Projects - Customisation Approaches Blog bot Dynamics CRM: Blogs 0 22.05.2009 07:05
Часовой пояс GMT +3, время: 12:26.
