Старый 13.01.2010, 23:08   #1
emeadaxsupport: Error in compiling datetime2str()
Источник: http://blogs.msdn.com/emeadaxsupport...etime2str.aspx
Lately we run into following problem. Doing different action in Dynamics AX client we got Dynamics AX 2009 Debugger pop up and following error:
Error executing code: Wrong argument type for function.
The problem was caused that application and Client was running on different build version.
Client was AX 2009 RTM (5.0.593.xxx) and application on 2009 SP1 (5.0.1000.52)
ax2009, версии, ошибка компиляции, ядро
Функция datetime2str и проблемы в Ах5 Delfins DAX: Программирование 6 26.11.2009 01:31
emeadaxsupport: The Dynamics AX Client sometimes terminates when displaying certain HTML pages in a Web browser control Blog bot DAX Blogs 0 15.10.2009 15:05
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 02:21.
