Старый 04.03.2010, 20:05   #1
Kashperuk Ivan: Highlighting your code on Blogger
Источник: http://kashperuk.blogspot.com/2010/0...ed-me-for.html
A couple of people have now asked me for the tool that I use for pasting the source code on my blog.
In order to use the same, you will have to change the template of your blog and include the following scrips:
After that, you will be able to create code by specifying the following:
Your code goes here...
Kashperuk Ivan: Performance optimization: Deleting inventory journal lines Blog bot DAX Blogs 0 08.02.2010 01:06
Kashperuk Ivan: SysCompilerTarget - compiling X++ code without showing the compilation window Blog bot DAX Blogs 0 24.11.2009 15:05
Kashperuk Ivan: Tool for protecting your Dynamics AX source code Blog bot DAX Blogs 0 12.12.2008 04:07
axcoder: Syntax highlighting of X++ code in your blog or site Blog bot DAX Blogs 0 16.01.2008 15:00
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 22:19.
