Старый 01.07.2010, 03:12   #1
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 5 has been released to Partner Source and Customer Source
Источник: http://blogs.technet.com/b/dynamicsa...er-source.aspx
Today, we're happy to announce to release of Dynamics AX 2009 Rollup 5 for RTM and SP1 customers. These releases are available on Partner Source and Customer Source.
Due to the cumulative nature of the rollups, RU-5 carries all the content that has been released in previous rollups (RU-1, RU-2, RU-3, RU-4).
Links to the RU-5 Knowledge Base articles:
За это сообщение автора поблагодарили: Poleax (1).
Старый 01.07.2010, 10:05   #2
Arijit Basu: Dynamics AX 2009 Rollup 5
Источник: http://feedproxy.google.com/~r/blogs...-rollup-5.html
Старый 01.07.2010, 10:59   #3
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
459 / 186 (7) ++++++
Записей в блоге: 6
документация на русском ожидается? Когда, где?
Старый 01.07.2010, 11:01   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Предлагаю обсуждать дальше в теме про RU5.
Ivanhoe as is..
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 4 has been released to Partner Source and Customer Source Blog bot DAX Blogs 13 15.04.2010 09:29
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 3 has been released to Partner Source and Customer Source Blog bot DAX Blogs 0 01.10.2009 10:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 2 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 10.07.2009 10:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 1 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 15.04.2009 10:05
Часовой пояс GMT +3, время: 22:03.
