Старый 21.09.2010, 13:05   #1
daxdilip: How to install AX Debugger without actually running the setup :-)
Источник: http://daxdilip.blogspot.com/2010/09...r-without.html
For troubleshooting one of our interface, I had to run the AX Debugger from AOS Server. And, on our DEV AOS Server, I didn't have the AX install/setup files.
So, I just tried to give this quick workaround a shot hoping that it works and it actually worked!
Copy the "AxDebug.exe" from my local box "C:\Program Files\Microsoft Dynamics AX\50\Client\Bin"
and just paste it in the path on the AOS box where client is installed and this did the trick!
No need to go through the boring installation, Quick and easy :-)
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
emeadaxsupport: How to install AX 4.0 Reporting Role with SSRS 2008 Blog bot DAX Blogs 2 23.01.2010 08:02
emeadaxsupport: AX 2009 Setup fails to install IIS Components on Windows Server 2008 R2 Blog bot DAX Blogs 0 12.01.2010 04:44
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
Часовой пояс GMT +3, время: 05:00.
