Старый 15.11.2010, 13:11   #1
25,644 / 848 (80) +++++++
daxdilip: Tip: How to display the AOS Name at the status bar
Источник: http://daxdilip.blogspot.com/2010/11...at-status.html
This is quite ignored but very useful tip if you are working on multi-environments, especially useful in our case, where we have 6 different environments like DEV/TEST/SANDPIT/TRAINING etc to name few.
Our AX Fellow blogger, Klaas has mentioned in his blogpost, Very handy tip, Keep up the good work.
http://www.artofcreation.be/2009/11/...in-status-bar/
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
gatesasbait: Showing Database name of current AOS in AX 4.0x title bar Blog bot DAX Blogs 0 18.12.2007 19:50
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
Часовой пояс GMT +3, время: 04:49.
