Старый 22.11.2010, 01:11   #1
xplusplus: Warning: Assignment/Comparison loses precision.
Источник: http://xplusplus.info/index.php/warn...ses-precision/
This warning appears when trying to convert Real or Int64 variables to int, like in the following example:
info(int2str(emplTable.RecId)); emplTable.RecId returns a Int64 value, and by converting it through int2str function we actually changing the data.
The solution is to use the correct converting function, in that case it is int642str()
info(int642str(emplTable.RecId));
xplusplus: Warning: Empty compound statement Blog bot DAX Blogs 2 22.11.2010 10:14
xplusplus: How to read data from text (.txt) file with AsciiIo Blog bot DAX Blogs 0 22.11.2010 01:11
emeadaxsupport: You get a warning message when deploying the AX 2009 smmOpportunityReports report library Blog bot DAX Blogs 0 19.02.2010 05:07
Dynamics AX: Dynamics AX 2009 - X++, C# Comparison Blog bot DAX Blogs 2 20.02.2009 13:21
Issues concerning X++: Getting rid of the "Loss of precision" warning message Blog bot DAX Blogs 2 12.07.2007 18:22
Часовой пояс GMT +3, время: 04:28.
