Dynamics AX Sustained Engineering: Financial Statement calculation column behavior with Currency Converter
Источник: http://blogs.technet.com/b/dynamicsa...converter.aspx
============== Problem: When using the currency converter on a Financial Statement, calculation columns are restated. In some cases, this may not be desirable as the calculation column may already contain information as needed. An example would be a calculation column consisting of a sum of two columns that contain secondary currency information. Resolution: To resolve this issue the class \Classes\LedgerBalanceSheetDimPrint\buildFields can be modified as follows. The changes consist of moving one of the case statements to an earlier point in the code. From: ... case LedgerColumnTypeDim::CurrentCur, LedgerColumnTypeDim::BudgetCur, LedgerColumnTypeDim::CovCur : reportRealField.extendedDataType(extendedtypenum(AmountCur)); reportRealField.dataMethod(#methodDisplayAmountCur); break; ... To: ... case LedgerColumnTypeDim::CurrentCur, LedgerColumnTypeDim::BudgetCur, LedgerColumnTypeDim::CovCur, LedgerColumnTypeDim::CalcExpression : reportRealField.extendedDataType(extendedtypenum(AmountCur)); reportRealField.dataMethod(#methodDisplayAmountCur); break; ... and remove\comment the code in the following case statement. case LedgerColumnTypeDim::CalcExpression : reportRealField.extendedDataType(extendedtypenum(AmountMST)); reportRealField.dataMethod(#methodDisplayAmountMst); break; Источник: http://blogs.technet.com/b/dynamicsa...converter.aspx
