Проблема после установки AX2009 RU7
При запуске клиента:
Невозможно выбрать запись в Данные о компании (CompanyInfo). Название компании: , . База данных SQL обнаружила ошибку. Object Server 02: The database reported (session 3 (Admin)): [Microsoft][SQL Native Client][SQL Server]Invalid column name 'ORGANIZATIONLEGALFORM_RU'.. The SQL statement was: "SELECT TOP 1 A.NAME,A.ADDRESS,A.PHONE,A.TELEFAX,A.BANK,A.GIRO,A.REGNUM,A.DEL_SYSSIGNADMIN,A.COREGNUM,A.VATNUM,A.CURRENCYCODE,A.IMPORTVATNUM,A.ZIPCODE,A.STATE,A.COUNTY,A.COUNTRYREGIONID,A.TELEX,A.URL,A.EMAIL,A.CELLULARPHONE,A.PHONELOCAL,A.UPSNUM,A.NAMECONTROL,A.DEL_SYSSIGNSENDEMAIL,A.EUROCURRENCYCODE,A.KEY_,A.SECONDARYCURRENCYCODE,A.DVRID,A.LANGUAGEID,A.INTRASTATCODE,A.BRANCHID,A.VATNUMBRANCHID,A.IMPORTVATNUMBRANCHID,A.ACTIVITYCODE,A.STREET,A.CITY,A.CONVERSIONDATE,A.PAGER,A.SMS,A.ADDRFORMAT,A.DEL_REFZIPCODE,A.PACKMATERIALFEELICENSENUM,A.DEL_COMPANYSIACODE,A.DEL_PAYMITEMCODEID,A.BANKCENTRALBANKPURPOSECODE,A.BANKCENTRALBANKPURPOSETEXT,A.SHIPPINGCALENDARID,A.PLANNINGCOMPANY,A.TAXREPRESENTATIVE,A.DEL_VATNUM_TH,A.FALLBACKINVENTLOCATIONID,A.BANKACCTUSEDFOR1099,A.SOFTWAREIDENTIFICATIONCODE_CA,A.TEMPLATEFOLDER_W,A.FEATURES_W,A.USESEVERALADDRESSFORMATTYP8058,A.INN_RU,A.CODEOKDP_RU,A.CODEOKPO_RU,A.RESIDENT_W,A.IMNSCODE_RU,A.IMNSNAME_RU,A.KPPU_RU,A.PFREGNUM_RU,A.ESTATE_RU,A.BUILDING_RU,A.SETTLEMENTID_RU,A.STREETID_RU,A.FLAT_RU,A.TOWNID_RU,A.RALIENCORPCOUNTRY,A.RALIENCORPNAME,A.DEL_RGNICODE,A.OKATO_RU,A.RENTRYDATE,A.RFULLNAME,A.OGRN_RU,A.DEL_VATREGNUM_PL,A.FSS_RU,A.ORGANIZATIONLEGALFORM_RU,A.SUBORDINATECODE_RU,A.FSSACCOUNT,A.MODIFIEDDATETIME,A.DEL_MODIFIEDTIME,A.MODIFIEDBY,A.RECVERSION,A.RECID,A.DEL_LOGO FROM COMPANYINFO A WHERE ((DATAAREAID=?) AND (KEY_=?)) ORDER BY A.DATAAREAID,A.KEY_" Msg 207, Level 16, State 1, Line 1 Invalid column name 'ORGANIZATIONLEGALFORM_RU'. Msg 207, Level 16, State 1, Line 1 Invalid column name 'SUBORDINATECODE_RU'. Msg 207, Level 16, State 1, Line 1 Invalid column name 'FSSACCOUNT'. Проблемные поля относятся к SL2. Установлена з.п. от RU6. Повторение чеклиста обновления или синхронизация таблицы CompanyInfo или рестарт АОСа помогает на день. После этого - повторение. Клиент и приложение ...4570 Куда дальше копать?
