Старый 25.11.2011, 17:11   #1
25,644 / 848 (80) +++++++
workflowax: Error executing code: FormDataSourceObject not initialised
Источник: http://workflowax.wordpress.com/2011...t-initialised/
Your workflow quick fix for the day:
Ok, so you’ve developed your workflow template, enabled your form for workflow, setup a configuration and are ready to give your workflow its first test run. You open your form and the first thing you get is the debugger with an error message: “Error executing code: FormDataSourceObject not initialized” Called from the SysWorkflowFormControls\initControls class.
Don’t worry, this is a very quick fix, and you, like I did, may kick yourself for forgetting. Open up your workflow enabled form in the AOT, navigate to Designs, Design, right click, select properties and select a valid data source. e.g.
No data source selected
Data source selected
workflowax: Business Connector code refresh Blog bot DAX Blogs 0 15.04.2011 13:11
workflowax: Why is my yellow workflow bar not displaying Blog bot DAX Blogs 0 20.09.2010 12:05
workflowax: Fields not appearing in Condition Editor Blog bot DAX Blogs 0 23.08.2010 11:05
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 20:49.
