Старый 28.02.2012, 12:11   #1
25,644 / 848 (80) +++++++
axforum blogs: Перебор содержимого папки в X++
Источник: http://axforum.info/forums/blog.php?b=321
Нашел замечательную статью, где описано как с помощью WinAPI из X++ перебрать содержимое папки.
static void FindFile(Args _args)
    #File
    FileName fullFileName(FileName _path, FileName _fileName)
        FileName    pathName;
        FileName    fileName;
        FileName    fileExtension;
        [pathName,fileName,fileExtension] = fileNameSplit(_fileName);
        return _path + '\\' + fileName + fileExtension;
    void findFiles(FileName _path,
                  FileName _fileName,
                  boolean _inclSubDir = true,
                  FileName _prefix = fullFileName(_path,_fileName))
        FileName    fileName;
        int         hdl;
        setprefix(_prefix);
        if (WinAPI::folderExists(_path))
            [hdl,fileName] = WinApi::findFirstFile(fullFileName(_path,_fileName));
            while (fileName)
                if (WinAPI::fileExists(fullFileName(_path,fileName)))
                    info(fileName);
                fileName = WinApi::findNextFile(hdl);
            WinApi::findClose(hdl);
            if (_inclSubDir)
                [hdl, fileName] = WinAPI::findFirstFile(_path+'\\'+#AllFiles);
                while (fileName)
                    if (strlwr(fileName) != strlwr(_fileName) &&
                        strlwr(fileName) != strlwr('.')       &&
                        strlwr(fileName) != strlwr('..')      &&
                        WinAPI::pathExists(fullFileName(_path,fileName))
                        findFiles(fullFileName(_path,fileName), _fileName, _inclSubDir, fileName);
    findFiles('c:\\Program Files','*.doc');
Microsoft Dynamics CRM Team Blog: CRM 2011 Chart Enhancements Blog bot Dynamics CRM: Blogs 0 25.01.2012 10:11
DynamicsAxSCM: Visualizing Security in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 29.08.2011 13:11
crminthefield: How to Create a Silverlight Web Resource that Interacts with CRM 2011 Forms Blog bot Dynamics CRM: Blogs 0 24.06.2011 04:17
Microsoft Dynamics CRM Team Blog: Welcome to the World of Dialogs - Part 1 Blog bot Dynamics CRM: Blogs 0 02.02.2011 21:11
DynamicsAxSCM: Personalization of Role Centers in Dynamics AX 2009 Blog bot DAX Blogs 0 21.06.2010 16:05
Часовой пояс GMT +3, время: 10:24.
