Старый 15.05.2012, 18:11   #1
ax-erp: Configuration in title bar
Источник: http://microsoft-dynamics-ax-erp.blo...title-bar.html
One common complaint with Dynamics AX 4.0 is that it is not possible for the user to determine in which environment they are working.
Particularly for consultants/developers who often have multiple AX applications open at one time, this is very frustrating and can easily lead to errors (developing in the wrong application). In Axapta 3.0 information was displayed in the title bar allowing users to determine the application, but this is missing in AX 4.0
This simple fix will display the configuration name in the main Dynamics AX window title bar. You need to simply override the workspaceWindowCreated() method in the info() class (special class nearly at the bottom of the Classes node in the AOT) and add a single line of code. After the change, the method should appear as follows:
void workspaceWindowCreated(int _hWnd)
    // Put workspace window specific initialization here.
    // Show config in title bar
    WinAPI::setWindowText(_hWnd, strFmt("%1 - %2", WinAPI::getWindowText(_hWnd), xInfo::configuration()));
Another option is shown below. This will put the current AOS and server name, as well as the logged in development layer, after the standard title bar text.
    SqlSystem       sqlSystem = new SqlSystem();
    LoginProperty   loginProperty = sqlSystem.createLoginProperty();
    // Show application details in title bar
    if (loginProperty)
        WinAPI::setWindowText(_hWnd, strFmt("%1 - %2@%3 (%4)", WinAPI::getWindowText(_hWnd), loginProperty.getDatabase(), loginProperty.getServer(), this.currentAOLayer()));
The details for these fixes came originally from posts to the microsoft public axapta newsgroup.
Alternative AX 3.0 Solution
The original solution for AX 3 used onEventGoingIdle to adapt the Window title. This is not optimal since this is called many thousands of times during the lifetime of an Axapta session. Unfortunalety, one can't simply use Info::startupPost() to set the title, as the Ax Client set the final title only after the startup cycle has completed. One workaround for this is to defer the execution of the title update using the setTimeOut() method with the idle flag set to true. This will delay the execution of the method in question to the point, where Axapta goes idle for the first time:
Addendum: It seems, that Axapta 3 resets the title bar now and again. I have not yet found the root cause of this. However, if you experience this problem, working around it is rather easy. Reschedule the CANUpdateWindowTitle to run every thirty seconds or so. This is not as stressfull as running it over and over again like the original solution did.
// Classes\Info\startupPost
void startupPost()
    // Needs delay until idle to allow Axapta to initialize fully
    this.setTimeOut(identifierStr(UpdateWindowTitle), 1, true);
The actual function in question is pretty straight forward:
// Classes\Info\UpdateWindowTitle
void CANUpdateWindowTitle()
    Session session;
    SQLSystem SQLSystem;
    #define.WM_SETTEXT(0x0c)
    int setWindowText(str title)
        int         ret;
        DLL         _DLL             = new DLL('USER32');
        DLLFunction _defwproc        = new DLLFunction(_DLL, 'DefWindowProcA');
        _defwproc.returns(ExtTypes:: DWord); // LRESULT
        _defwproc.arg(ExtTypes:: DWord);     // handle window
        _defwproc.arg(ExtTypes:: DWord);     // message
        _defwproc.arg(ExtTypes:: DWord);     // wparm
        _defwproc.arg(ExtTypes::String);     // lparm
        ret = _defwproc.call(infolog.hWnd(), #WM_SETTEXT, 0, title);
        return ret;
    session = new Session();
    SQLSystem = new SQLSystem();
    if (isAOS())
        setWindowText(strfmt("Axapta - %1", session.AOSName()));
    else
        setWindowText(strfmt("Axapta 2T - DB %1 on %2 ", SQLSystem.loginDatabase(), SQLSystem.loginServer()));
    // In case you experience Problems: Enable this to rerun every 30 Seconds if Axapta changes
    // the title back to the default now and then.
    // this.setTimeOut(identifierStr(CANUpdateWindowTitle), 30000);
Original AX 3.0 solution
from AxForum
\Classes\Info\onEventGoingIdle
//Event fired by kernel when the client goes idle.
//It is not fired during CTRL-Break dialog.
void onEventGoingIdle()
    this.operationProgressClear();
    this.endLengthyOperation(true);
    // there should be a user who will work if error occured
    if(strLwr(curUserID())!='admin')
        TitleChanger::changeTitle();
TitleChanger::changeTitle:
static void changeTitle()
    #define.WM_SETTEXT(0x000C)
    str         caption;
    str prefix=new Session().AOSName()+": ";
    int  defWindowProc(
                               int              _handle,
                               int              _msg,
                               int              _wParam,
                               str              _lParam )
        int         ret;
        return  _defwproc.call(_handle, _msg, _wParam, _lParam);
    caption = winapi::getWindowText(infolog.hWnd());
    if(!StrUtils::startsWith(caption, prefix))
        defWindowProc(infolog.hWnd(), #WM_SETTEXT, 0, prefix + caption);
StrUtils::startsWith:
// string _s begins with _suffix
static boolean startsWith(str _s, str _prefix)
    return
        strLen(_s)>=strLen(_prefix)
        subStr(_s, 1, strLen(_prefix))==_prefix;
Последний раз редактировалось Poleax; 16.05.2012 в 12:18. Причина: оформление
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 20:18.
