Старый 05.09.2012, 15:11   #1
axaptacorner: Generate number Sequence
Источник: http://axaptacorner.blogspot.com/201...ence_8531.html
Suppose we want create number sequence for Test field on form in General ledger module
Consideration: EDT-Test, Table-TestTable and Form- TestTable
Step1. Create new EDT with name Test
Step 2. Modify load module() method on NumberSeqModuleLedger class
datatype.parmDatatypeId(extendedTypeNum(Test));
datatype.parmReferenceHelp(literalStr("Test"));
datatype.parmWizardIsManual(NoYes::No);
datatype.parmWizardIsChangeDownAllowed(NoYes::No);
datatype.parmWizardIsChangeUpAllowed(NoYes::No);
datatype.parmWizardHighest(999);
datatype.parmSortField(30);
datatype.addParameterType(NumberSeqParameterType::DataArea, true, false);
this.create(datatype);
Step 3.Create a method on LedgerParameters Table
clientserverstatic NumberSequenceReference numRefTest()
return NumberSeqReference::findReference(extendedTypeNum(Test));
Step 4.Write and run following job
staticvoid NumberSeqLoadAll(Args _args)
NumberSeqApplicationModule::loadAll();
Step 5.Then run the wizard
Organization Administration -> CommonForms -> Numbersequences->Numbersequences-> Generate -> run the wizard.
Step 6.Now we have to check the number sequence is correctly working for that write a job:
staticvoid NumSeq(Args _args)
NumberSeq numberSeq;
Test num;
numberSeq = NumberSeq::newGetNum(ProjParameters:: numRefTest ());
num = numberSeq.num();
info(num);
Step 7.Now we want that Number Sequence in form level(Test Table):
Write below code in class declaration
publicclass FormRun extends ObjectRun
NumberSeqFormHandler numberSeqFormHandler;
Step 8.Write the NumberSeqFormHandler() in form methods node.
NumberSeqFormHandler numberSeqFormHandler()
if (!numberSeqFormHandler)
numberSeqFormHandler = NumberSeqFormHandler::newForm(LedgerParameters:: numRefTest ().NumberSequenceId,
element,
TestTable_DS,
fieldNum(TestTable, Test)
return numberSeqFormHandler;
Step 9.Write the Create(),Delete(),Write() , Validate Write(),Link Active()on the Data source methods node.
Create() Method
void create(boolean append = false,
boolean extern = false)
element.numberSeqFormHandler().formMethodDataSourceCreatePre();
super(append);
if (!extern)
element.numberSeqFormHandler().formMethodDataSourceCreate(true);
Delete() Method
publicvoid delete()
element.numberSeqFormHandler().formMethodDataSourceDelete();
super();
Write()Method
publicvoid write()
super();
element.numberSeqFormHandler().formMethodDataSourceWrite();
Validate Write() Method
publicboolean validateWrite()
boolean ret;
ret = super();
ret = element.numberSeqFormHandler().formMethodDataSourceValidateWrite(ret) && ret;
if (ret)
TestTable.validateWrite();
return ret;
Link Active() Method
publicvoid linkActive()
element.numberSeqFormHandler().formMethodDataSourceLinkActive();
super();
Step 10.Finally add Close() method on form
void close()
if (numberSeqFormHandler)
numberSeqFormHandler.formMethodClose();
super();
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
sumitsaxfactor: Generating Next Number Sequence in SQL Blog bot DAX Blogs 0 03.05.2011 21:11
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Часовой пояс GMT +3, время: 11:01.
