Ax 2009 AIF Web service
Hi,
In some cases inbound message can have field values which should convert to other values in Ax and assign to certain field. For regular AIF services it is possible to create additional Ax<table>.parm<field> methods without real field behaind. I tried to use the same for web services by using 'find' action, but system asks for real field. Is it possible to convert somehow incoming value to other value and assign to certain field? An example, xml sends <field>1</field>, but in Ax it should be converted to 'Yes'. |
