Старый 29.08.2012, 14:11   #1
mfp: Pre-order Inside Microsoft Dynamics AX 2012
Источник: http://blogs.msdn.com/b/mfp/archive/...s-ax-2012.aspx
We are heading for a true power demonstration from Microsoft in the fall of 2012. A long line of exciting products will be released, including Windows 8, Windows Server 2012 and Microsoft Surface
…and the probably most anticipated of them all:
Inside Dynamics AX 2012.
Pre-order your copy today.
Abstract:
Dig into the architecture and internals of Microsoft Dynamics AX 2012 - with firsthand insights from the team that designed and developed it. Targeted for solution developers and system implementers, this guide focuses on programming and customization capabilities - including key architectural principles, the application model, framework, and tools. Topics include: Architecture and development environment, including MorphX Microsoft Visual Studio tools for Microsoft Dynamics AX X++ programming language Microsoft SQL Server reporting and analytics Models Core development concepts Extending and customizing Microsoft Dynamics AX Performance and security considerations Workflow Best practices Note: Readers should have working knowledge of SQL and OOP concepts to gain max benefit from this book.
Старый 29.08.2012, 14:11   #2
palleagermark: Inside Microsoft Dynamics AX 2012 available for pre-order
Источник: http://palleagermark.blogspot.com/20...lable-for.html
You can now pre-order the newest member of the Inside Microsoft Dynamics AX book series from Amazon.
It does'nt seem like it's comming in a Kindle edition, but one can only hope.
Старый 29.08.2012, 18:08   #3
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Интересно, а кто автор?
Последние две по 4,0 и 2009 был Пенопидан, сорри если в русской трансляции по-коверкал фамилию этого интересного человека.
Axapta book for developer
Старый 29.08.2012, 22:04   #4
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
Понтоппидан. Авторов, как и раньше, будет несколько. И он среди них.
Старый 30.08.2012, 17:23   #5
fed is offline
fed
Аватар для fed
2,914 / 5737 (197) ++++++++++
Поскольку на стеб по поводу обложки я пустил другую тему, в эту размещу конструктив
Inside Dynamics AX 2009 можно купить в электронном виде вот здесь:
Есть большая надежда, что когда аналогичная книжка по DAX2012 выйдет, ее можно будет купить в электронном виде вот здесь.
Старый 29.10.2012, 22:33   #6
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
К слову, на счет покупки книг на O'Reilly - вдруг кто не знает: на книги MS Press в печатном и электронном виде там можно получить 40% и 50% скидку, соответственно, введя скидышный код MSINT
За это сообщение автора поблагодарили: Vadik (1).
Старый 12.11.2012, 02:20   #7
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Ага
-ТСЯ или -ТЬСЯ ?
Старый 12.11.2012, 03:04   #8
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
Записей в блоге: 1
на известных торрентах уже появилась, что приятно
Старый 27.11.2012, 11:46   #9
Vadik is offline
Vadik
Аватар для Vadik
Наткнулся на книжку на Google books
-ТСЯ или -ТЬСЯ ?
ax2012, book, книга
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
AIF: Microsoft Dynamics AX 2012 Services and AIF White Papers Blog bot DAX Blogs 0 16.06.2011 00:11
dynamics-ax: Microsoft Dynamics AX 2012 Excel Add-in Blog bot DAX Blogs 0 08.06.2011 08:12
dynamics-ax: Microsoft Highlights New ERP Public Sector Capabilities for AX 2012 Blog bot DAX Blogs 0 23.05.2011 19:11
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 09:50.
