Старый 28.11.2012, 12:11   #1
Malaysia: Processing a project journal
Источник: http://axmas.blogspot.com/2012/11/pr...t-journal.html
1. In the AOT, create a new job named ProjJournalCreate with the following code:
static void ProjJournalCreate(Args _args)
ProjJournalTable jourTable;
ProjJournalTrans jourTrans;
ProjJournalTableData jourTableData;
ProjJournalTransData jourTransData;
ProjJournalStatic jourStatic;
ttsBegin;
jourTableData = JournalTableData::newTable(jourTable);
jourTable.JournalId = jourTableData.nextJournalId();
jourTable.JournalType = ProjJournalType::Hour;
jourTable.JournalNameId = 'Hours';
jourTableData.initFromJournalName(ProjJournalName::find(jourTable.JournalNameId));
jourStatic = jourTableData.journalStatic();
jourTransData = jourStatic.newJournalTransData(jourTrans, jourTableData);
jourTransData.initFromJournalTable();
jourTrans.initValue();
jourTrans.ProjId = '10001';
jourTrans.initFromProjTable(ProjTable::find(jourTrans.ProjId));
jourTrans.TransDate = systemDateGet();
jourTrans.ProjTransDate = jourTrans.TransDate;
jourTrans.CategoryId = 'Design';
jourTrans.setHourCostPrice();
jourTrans.setHourSalesPrice();
jourTrans.TaxItemGroupId = ProjCategory::find(jourTrans.CategoryId).TaxItemGroupId;
jourTrans.Worker = HcmWorker::findByPersonnelNumber('000062').RecId;
jourTrans.Txt = 'Design documentation';
jourTrans.Qty = 8;
jourTransData.create();
jourTable.insert();
ttsCommit;
info(strFmt("Journal '%1' has been created", jourTable.JournalId));
2. Run the job and check the results by going to Project management and accounting | Journals | Hour:
3. Click on the Lines button to open the journal lines, and notice the newly
created record:
Malaysia: Posting a general journal Blog bot DAX Blogs 0 27.11.2012 15:11
Malaysia: Creating a general journal Blog bot DAX Blogs 0 27.11.2012 15:11
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 10:16.
