Старый 07.12.2012, 17:11   #1
emeadaxsupport: Dynamics AX 2009 EE layer and CRM connector
Источник: http://blogs.msdn.com/b/axsupport/ar...connector.aspx
Lately we encounter problem when integrating CRM connector with Dynamics AX 2009 EE layer. While running map AX Enumerated Values to Picklist you getting error in CRM Connector.
The map does not synchronize correctly and the values are not available. To overcome this issue you need to install hotfix for EE GLS layer. The KB article number is 2778999 and should available soon.
If it is still not available please contact Dynamics AX support team.
Microsoft Dynamics CRM Team Blog: Creating Heat Maps with Bing Maps and Dynamics CRM Blog bot Dynamics CRM: Blogs 0 31.10.2012 03:16
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
CRM DE LA CREME! Update Rollup 9 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 12.02.2010 16:05
lcash: Release of Microsoft Dynamics AX 2009 Demonstration Toolkit – Refresh 2 Blog bot DAX Blogs 5 22.07.2009 12:48
Часовой пояс GMT +3, время: 18:45.
