Старый 07.04.2013, 06:58   #1
25,644 / 848 (80) +++++++
bojensen: Dynamics Ax Internals: Quick walk-through of developing a report in Ax2012
Источник: http://blogs.bojensen.eu/?p=4685
  The following is a quick-and-dirty approach to building a basic SSRS report in Ax2012. This uses an Ax query as the primary datasource, and uses display methods on the table(s) to retrieve additional information. This is not an approach you should take for all reports, particularly those that require more complex calculations or parameters, [...]
bojensen: Use a Dynamics AX display method in SSRS report | Arjen Stolk Blog bot DAX Blogs 0 20.03.2013 01:11
bojensen: How to Set the Query Range on a SSRS Report | Amir’s Microsoft Dynamics AX space Blog bot DAX Blogs 0 18.03.2013 17:11
bojensen: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] | Sreenath Reddy G – Dynamics AX Consultant’s Blog Blog bot DAX Blogs 0 15.03.2013 17:11
saveenr: Dynamics AX 2012: An Introduction to Report Data Providers Blog bot DAX Blogs 0 07.03.2011 12:11
Часовой пояс GMT +3, время: 03:20.
