Старый 24.06.2013, 17:11   #1
emeadaxsupport: Negative lines in BOM are not considered at Master scheduling
Источник: http://blogs.msdn.com/b/axsupport/ar...cheduling.aspx
A BOM has got several lines, one or more with negative quantity. Assumed, there is nothing on hand and a sales order for this BOM exists. Then Master scheduling creates a planned production order but it doesn’t calculate the negative lines as receipt.
MRP is calculating demands. Negative lines have no demand, no need to cover something. It doesn’t matter if the BOM line type is Item, Phantom, Pegged supply (AX2012) / Production (earlier versions), or Vendor.
emeadaxsupport: Scheduling Time-out parameter setting in AX 2012 Blog bot DAX Blogs 0 23.04.2013 19:11
emeadaxsupport: Dynamics AX 2009 - A negative receipt is not allowed on a Project PO - How to address this situation Blog bot DAX Blogs 0 15.03.2013 17:11
emeadaxsupport: Can't find the packing slip during invoice matching or is the invoice form not showing any order lines? Blog bot DAX Blogs 0 11.06.2012 22:13
emeadaxsupport: Measure 'Total purchases' in Accounts payable cubes for dimension 'Vendor Master' shows values Uknown Blog bot DAX Blogs 0 01.03.2011 22:11
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 12:22.
