Старый 12.07.2013, 14:11   #1
fatihdemirci: How to release products to all companies.
Источник: http://www.fatihdemirci.net/index.ph...all-companies/
Hi, As you know with Dynamics AX 2012, you have to create a product first and then release to the product to companies. You can release which company do you want. In my company there is a request to release product all companies automaticly. I have some research and found good post and methods about [...]
fatihdemirci: How to display only one attribute value from DefaultDimension Blog bot DAX Blogs 0 14.05.2013 17:11
fatihdemirci: How to modify MainAccount Lookup in Segmented Entry Control Blog bot DAX Blogs 0 08.05.2013 17:11
DynamicsAxSCM: Troubleshooting the product release process Blog bot DAX Blogs 0 05.10.2012 17:11
dax-lessons: Release products to the legal entities using X++ [Dynamics AX 2012] Blog bot DAX Blogs 0 13.11.2011 15:13
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
Часовой пояс GMT +3, время: 01:19.
