Старый 30.07.2013, 21:11   #1
dynamicscare: Remember to Add Your Financial Dimensions to Your Cubes
Источник: http://dynamicscare.com/blog/remembe...to-your-cubes/
I wanted to post a PSA about the Dynamics AX 2012 R2 cubes and step that I often overlook during the installation. The step is on adding financial dimensions to the cubes. It’s a very simple procedure and can be found here: http://technet.microsoft.com/en-us/l.../hh128830.aspx In short, when you first deploy the cubes, you may not have [...]
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions [AX 2012] Blog bot DAX Blogs 0 18.01.2012 11:11
sumitsaxfactor: Ledger Accounts and Financial Dimensions Blog bot DAX Blogs 0 13.12.2011 22:11
emeadaxsupport: How to add financial dimension to Dynamics AX Default cubes Blog bot DAX Blogs 0 13.01.2011 16:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
Часовой пояс GMT +3, время: 12:20.
